upfitter switch - Ford Powerstroke Diesel Forum
Old 05-08-2011, 08:33 AM
IU Hoosier Fan
Question upfitter switch
Has anyone/can it be done:
install a upfitter switch in a 03-04 Superduty/Excursion?
I'm not really too worried about the tow command... It would be neat to install that also... but just really wanna try to put the upfitter switches in....
Old 05-08-2011, 09:28 AM
Pointless Poster
hm could be interesting..... subscribing
Old 05-08-2011, 09:45 AM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
I believe it can be done, and the wires are all ready there, I just baught some $3 switchs and some $5 switch plate covers off a peterbilt offline and put them in
total cost was like $30
Old 05-08-2011, 09:47 AM
Almostdunfukinwidit
It can be done Ryan.
But it wont be as easy as it is on an 05 up. You need an 05 SD lower dash panel.
You need a keyed 50 amp power source. Thats it
Old 05-08-2011, 09:52 AM
Illiana Chapter Director
Will the lower dash panel bolt right in? I thought they were made differently.
Old 05-08-2011, 09:54 AM
Almostdunfukinwidit
There will be a bit of a gap between the lower and upper unless you replace the upper too
Old 05-08-2011, 04:52 PM
IU Hoosier Fan
What do you mean by keyed?
So... wiring up the upfitter switch and tow commnad won't be to hard to do?
(sorry haven't really looked into it yet)
Old 05-08-2011, 04:53 PM
Have to wire it so the switches have power when key is turned on.
Old 05-08-2011, 04:54 PM
IU Hoosier Fan
Old 05-08-2011, 04:55 PM
Almostdunfukinwidit
Wont be able to do tow command on an 04 or older or an ex.
Tow command requires a different master cylinder to work correctly
