05 XLT, wanting to add some Lariat options - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-21-2011, 03:11 PM Thread Starter
I have access to a parts truck that is an 06 Lariat. Would like to add the steering wheel with controls, 6-disk factory radio with digital climate controls. Is my 05 XLT pre-wired to install this stuff? Would also like to have the info center in the gauge cluster. Does the cluster have to be changed out?
Tried posting this in the electronics forum with no responses....maybe someone here will know.
Thanks
Kappa Sig is offline
post #2 of 11 Old 04-24-2011, 09:04 AM
I have an 07 XLT and im wanting to add the radio controls as well.
So im bumping this to move it up.
D White.
dwhite316 is offline
post #3 of 11 Old 04-24-2011, 09:18 AM
i_gibson13's Avatar
Ya I want to get the climate control for my 05xlt and the thing that tells fuel mileage. Mine only does trip and hours. So I want to know if the stuff will go in too.
2005 F-250 xlt 6.0 ccsb
-4.5 inch carli starter lift(front)
-5 inch icon blocks(back)
-Bilstein 5100's
-35x12.5 Nitto Trail Grapplers
-18x9 XD series Monsters
-Harley Headlights HID's
-SCTx3
-Swamps 58v FICM
-Edge Insight CTS
-5" diamond eye exhaust
-Focal Components
-2 MB Quart Shallow Mount Subs
-Upgraded Black Leather
-Astro Auto Start
1994 Thunderbird Super Coupe 5spd
2006 RM 250
i_gibson13 is offline
post #4 of 11 Old 05-07-2011, 11:48 AM
police251's Avatar
I want the same how are we going to find out... I also want to add the stock fog lamps but dont know it the wires are already there.
police251 is offline
post #5 of 11 Old 05-07-2011, 01:22 PM
i_gibson13's Avatar
I guess we should have just bought Lariats. lol. You could probably wire in the fog lamps up to the fuse box for power. Then tap into the wire and hook it up to one of your auxilary switches(if you have them) so you can turn them on or off. If no auxilary switches you can get a switch from radio shack that would work.
-Bilstein 5100's
-SCTx3
-Swamps 58v FICM
-Edge Insight CTS
-Focal Components
-Astro Auto Start
2006 RM 250
post #6 of 11 Old 05-07-2011, 01:49 PM
RRF985's Avatar
None of the trucks are prewired for any of that stuff. You will need essentially a whole donor vehicle for wiring harnesses, connectors and other parts. You would probably have to do some custom wiring as well. Good luck if you actually do dive into this project.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #7 of 11 Old 05-07-2011, 10:21 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
To ad the digital hvac you need to pull the dash, change the dash harness and all the ductwork. the digital hvac uses dual blend doors/actuators vs a single unit for manual hvac, and the harness is totally different. As for the radio, the clockspring has the wiring in it, but the pins are empty. It would be easiest to change the entire dash harness and the column.
dazdillenger is offline
post #8 of 11 Old 05-07-2011, 10:23 PM
as for the fog lights, look on the drivers side frame rail right under the abs module-there should be a round plug with a cap on it. That's the fog light plug. Some trucks have it, some don't. My xlt did.
post #9 of 11 Old 03-02-2012, 06:52 PM
baysic's Avatar
i know someone on here has done the diy on the gauge cluster, made the info on the cluster work...
baysic is offline
post #10 of 11 Old 03-24-2012, 10:24 PM
WDCDAVE's Avatar
dazdiillenger posted a write up on the cluster followed it and now have the info centre working easy if you follow his directions its in the cluster swap write up ,like he said some have the fog light wires some dont mine did.The cluster works even with out the mirror as I figure I know which way I am going most of the time.LOL
Made to be drivin hard.This is how I decided to stick with the 04-06 6.0
06 F-350 Lariat 4 in on 35s eagle eyes 248 k
06 Lariat Dually 367 k
05 XLT Super-cab fancy paint and 20 in rims 145k
05 XLT Dually kinda stock but have plans 288 km
99 F250 7.3 just a cool truck 185 k sold
09 F-150 King Ranch The cruiser
06 F-350 XLT 178 km
06 F-350 XL Super-cab 147km
01 F-350 XLT Deck Truck 06 front clip 288 KM 7.3
2010 F-350 Dually slightly modded bought at 58,000 pushing 259k
WDCDAVE is offline
