How to remove door panel - Ford Powerstroke Diesel Forum
Old 04-06-2011, 05:25 PM
Ok so I tried to remove my door panel by trying to pry the bottom left corner when I heard a loud snap and realized I broke something so I left it alone..Than took it for a ride and heard the broken piece rattling in the bottom of the door. How do I get this thing off?...Its an 05
Old 04-06-2011, 05:29 PM
JJR JJR is offline
Pretty sure you just pop out the courtesy light and remove the screw then just lift the door panel up and off.
Old 04-06-2011, 05:53 PM
Remove the screws at the handle and red reflector. Maybe another one, don't remember.
Then, LIFT the panel. You have already broken some hooks.............
Old 04-06-2011, 06:11 PM
the screws are behind the reflector and the window switch cover. then pull up
Old 04-06-2011, 06:32 PM
Thx guys,i'll give it a shot tomorrow...Went to depot and somebody hit my driver side rocker panel.....so i figured I would try and push it back out from the inside..
