| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
empty switch hole?
hey everyone, i have an 05 sd , beside the steering wheel on the left side i have a small oval hole in the dash, there used to be a cover in it, but im trying to figure out what switch goes in there??
i cant tell from my work trucks what goes in there cause thats where they mounted the hydraluic box lift switch does anyone know the switch im talking about |
can you take a pic of the hole? almost sounds like where the switch for the power pedals is
It is for the power adjustable pedals, Here's the switch on mine:
aren't centered![]() ![]()
And you can't count! There are 3 custom switches
And I like them! What is the one on the left for?
It is a lighted pushbutton switch wired directly to my cargo light so I don't have to turn on my interior lights to use the cargo light. |
Good idea. Where did you hook the switch in at? Right into the switch on the dash? If so, which wire did you use off that switch?
You have to run a separate wire from the switch all the way to the cargo light because the cargo light is only wired into the dome light from the factory. I just ran the wire from the switch down to the drivers side doorsil, then under the doorsil to the rear of the cab, then up around the rear window to the cargo light. Then just cut the factory wire between the cargo light and the dome light and splice in the new wire from the switch. And I just tapped into the constant power wire that feeds the headlight switch so that I don't need the key on to use the cargo light. The switches are from Radio Shack. |
anyone have a pn# for the plate that goes where the adjustable pedal switch is?
or have an extra lol |
