*PICS* RED LED interior and dash light conversion - Ford Powerstroke Diesel Forum
Old 02-01-2011, 06:47 PM
Truck : 2006 F350 with electronic climate control, Steering wheel controls, Aux switches and built in Brake controller.
For anyone thinking about attempting this on a newer truck like mine, warning! It is a very time consuming project and will try your patients.
as for lights I got them from, (Red 45 degree) You will need 25-29 of these LEDs depending on what you decide to use for the AUX switch's. that being said get a buffer of about 10 more to cover braking and misc damage.
Super Bright LEDs - Component LEDs
And for the climate control and steering wheel lights I could not find the small flat single diode lights in components so I used the non waterproof flexible LED strips. I took these and removed each individual LED and re used on the climate control and steering wheel. These LED strips come in half meter, meter and so on, I just got away with a half meter but would suggest getting a full meter for the little extra money. Again you need 25-29 of these depending on what you decide to use for AUX switch's.
NFLS & WFLS series Flexible Light Strips
This is a web page showing resistor colors
http://www.bpesolutions.com/atechnic...storCharts.pdf
Here is picture of the 2 styles of LEDs I used
For the door window switches I ended up using 150k ohm resistors, this may seem like a big resistor but it dims the lights just right in my opinion. It might be because of the LED I used. To get the switches apart you need to carefully pry the top part of the switch off the rest of it, get a small screwdriver under one side and pry up.
For the drivers door switch I used 3.6k ohm resistors and put them in line with the LEDs, this was one of the first ones I did so I did not get into changing the factory resistors already in the circuit board.
For the head light switch their is only one LED to change, the light from the single LED is then spread over with a prism. This LED I used 3.6k ohm resistor in line as well.
The back up sensor switch was a little bit of a pain to fit the LED and resistor in. I used a 10k ohm Resistor but probably could go up to a 15k ohm in my opinion. Also the LED needs to be filed down just a little so that it fits in the switch when you press it.
The electric back window switch i used a 6.8k ohm resistor and again had to file down the top of the LED so it fit properly.
4x4 switch, I believe you can buy this extended Light base with a LED in it but i did not have so i just rigged it with a 820 ohm resistor. This LED for the 4x4 switch uses the same idea and the headlight switch with the prism plastic and only one LED therefore needed to be brighter.
Now for the climate control! This was tricky because the LEDs are smaller and everything is done on the circuit board. The LEDs are all on the front and the resistors are all on the back side. You need to follow the circuit board lines to find out exactly what resistors to change. I believe they are 102 from factors and their all in pairs I replaced them with 18k ohm resistors. The display for the climate control, pop out the green plastic screen and I used a piece of red stain glass, easy to get and very cheep or even free from hobby store.
The steering wheel remote switches are press fit into the steering wheel leather. Carefully pry out the switches watching not to pull it out far, ford does not give much slack in the wiring harness. These LEDs are the same as used on the climate control, the factory resistors I believe on this one is 122 ohm factory. I replaced with 27k ohm resistors.
Refer to the pictures for rough lay out of where the resistors are.
The Aux switches I do not have pictures for so you'll have to attack them yourselves. The factory LEDs in the AUX switch's were domed single diode LEDs similar to the electronic climate control. I did not have the single diode LEDs at the time so I rigged it to work with the 3mm LEDs, may need to trim bit of plastic on dividers inside switch.
The built in brake controller is tricky to get apart but once apart I just straight changed the green LEDs to red and put back together, did not change any resistors, they are a little brighter but I don't mind. The actual green LED that reads out the braking for the trailer I did not change because that would mean trying to change the whole LED light board. Ill just live with the green LEDs when towing a trailer.
This is the outcome when all done. Sorry for the bad picture i will try and get better ones of it all lit up at night. Also waiting on a custom gauge face to finish it off, will post pictures of that install when it is done.
Last edited by HOSS-06; 12-28-2012 at 02:25 PM. Reason: Pictures no longer were showing
Old 02-01-2011, 07:16 PM
Looks awsomeNice write up!
Old 02-01-2011, 07:55 PM
looks good, would love to do this but don't have the patients to do it.
Old 02-01-2011, 08:27 PM
Send a message via MSN to Jetmek319 Send a message via Yahoo to Jetmek319
Excellent write up Hoss> Looks like a project for me in the near future!!!
Thanks for the time and effort!!
Old 02-01-2011, 08:33 PM
Send a message via AIM to A8050266 Send a message via MSN to A8050266 Send a message via Yahoo to A8050266
Nice job and pics.
Old 02-01-2011, 09:20 PM
Feedback Score: 4 reviews
If you had to guess, how long did this take you? By the way...amazing job!!!
Old 02-02-2011, 02:29 PM
Everyone I edited the write up to tell how many LEDs were used, plus a little more on the AUX switch's.
Thanks everyone for the complements, makes it all the more worth it!
I would have loved to have a write up when i first started so I hope it helps someone.
RollinEarly99 to be honest I cant really say how long it took, I started in the summer when I had some extra time but then got busy at work and ran out of LEDs, was just able to finish it now. keeping in mind I did not have a write up to follow or any knowledge of the switch's and was just digging into it, it took me probably double what it should have. If you sat down to just do it without any distractions and had a proper work area with tools maybe take about 8 hours.
With the write up you have an idea of what size resistors to use so that saves a ton of time, I did a couple switch's a night and would use one resistor check it in the truck, change it and keep going till I found the write size.
Old 02-03-2011, 08:12 AM
Wow, that looks great. Great write up too. Electrical stuff boggles my mind, wish I had the know how to do it. Great job
Old 02-03-2011, 08:30 AM
That looks really nice. Good job.
Old 02-05-2011, 09:19 AM
Added a resistor diagram link up at the top of the write up!
