(help) Steering wheel removal - Ford Powerstroke Diesel Forum
Old 01-14-2011, 11:05 AM
Hey guys I need help. I have to change my clock spring in my steering wheel and im not exactly sure how to remove it and the airbag.
Any help would be great
Thanks
I took a look at it yesterday and figured it out. . so im good Thx
This can be removed!!
Old 01-17-2011, 04:29 PM
Very good ?
Subscribing
Old 01-28-2011, 04:07 PM
Write up to folllow? My airbag light is on too and this is what I suspect.
Old 02-01-2011, 01:08 PM
Hey guys sorry I have not been on in a while. It is however not that hard.
First unplug your batteries; this is very important step when working with the air bag
Then you need to look on the back of the steering wheel, there are 2 tabs that pop out. Remove them and under you will find 2 hex head bolts.
Remove the hex head bolts and the air bag will pull off.
Unplug all wiring harnesses
Then use a steering wheel puller to remove the steering wheel.
The clock spring then is easily removed
Hope this helps.
