ATC damper motor install - Ford Powerstroke Diesel Forum
Old 12-26-2010, 01:05 AM
My damper motor recently started slipping causing a thumping noise behind my my glove box. It is the small electric motor that blends the hot and cold air via a damper. I purchased a new motor and was wondering if there was a certain procedure I have to follow for the install ? Do I have to set it for full cooling or heating and position the damper acordingly before I snap it into place ? Or will it find itself once it has been installed ? Sory for the stupid question, but I would rather ask then cause myself a headache down the road.
Thanks in advance for any info.
Old 02-03-2011, 10:51 AM
jnjlizak,did you get it figured out.I'm asking because my truck the air from the vents flips from hot to cold when ever it wants.Was your's doing the same thing or was it just making noise.Thanks for any info.
Old 02-03-2011, 01:12 PM
Mine was making noise due to a bad damper motor. It sounds like you may have the same type of problem. Right behind the glove box is your heater core. Just to the left and on top is the motor that modulates the damper from hot to cold. I have a lariat which has the digital temp controls. After replacing the motor (30 minute job at the most) my problem was solved. I opened up the old motor and found a broken tooth from a plastic gear inside. About a year ago I had a different issue. My vent positions would not change. The air would only blow out the defroster position. That ended up being a bad relay which ran the vacuum pump under the hood. I hope this helps you diagnose your problem. If it is the damper motor behind the glove box save yourself some time and a major headache. Spend the money and buy it from FORD. I first bought one form Checker Auto. Got home, put it in and the damn thing didn't work. I had to do the job twice plus take it back and do a return. Should have bought it from Ford in the first place.
Old 02-03-2011, 01:18 PM
A few people on this Forum put me onto this dealers sight for parts. They are selling them at cost + 10% if you call them and mention thier website, or place an order online. Really nice guys to deal with. No one else that I have found yet can come close to thier prices.
Tousley Ford
Old 02-03-2011, 01:57 PM
Thanks for the info,I'm going to look into it.Hopefully going to bring it into my mechanic tomorrow to diagnose it properly.I'll check into Tousley ford also but I think the shipping may get alittle pricey,I'm in Ontario Canada.Thanks again for your help.
Old 02-03-2011, 09:16 PM
No problem. Hoped I helped :-) Let me know what you find for future reference.
Old 02-04-2011, 02:43 PM
It turns out it's the water pump.Had the truck idling outside at my mechanics and noticed the degas bottle filling up to over flowing,went to ford right away talked to the deisel service advicer and after a 15 minute discussion he said to try replacing the thermostat first which I did and it didn't fix the problem called him about it and he said it is the water pump.So I ask him if he was going to replace it since they had just put one in it in september under warranty,he said no because there is no warranty left on the truck now.So I'm going to call ford direct and see if they'll doing anything,I doubt they will though.So basically I'm looking at a $1000 repair bill to replace a 5 month old factory ford part.If I could figure out away to dump the truck with out getting sued I would.I think I'd rather put $5000 into my 95 dodge with the cummins then have to keep doing repairs on this thing and get very poor fuel mileage at the same time.It's a nice driving truck but not for $30,000 plus on going repairs.Anyway,Thanks for your help and I wish it was the same problem you had.LOL.
