Switch panel - Ford Powerstroke Diesel Forum
Old 11-22-2010, 11:54 AM
Switch panel
If my truck already has the integrated brake controller. Is there a kit, or can you buy the switch panel from ford?
Old 11-22-2010, 12:14 PM
If you mean the upfitter switch setup yes you can get that as a seperate item. It takes the other half of the cubby your IBC is in. FYI I'd check ebay. They are probably quite a bit cheaper there.
Old 11-30-2010, 09:07 AM
did the have the upfitter switches in 04?
