Aftermarket seats, 2004 - Ford Powerstroke Diesel Forum
Old 11-12-2010, 09:47 AM
Have any of you swapped your OEM seats and center console out for any after market sets?
I would love to have some Beard suspension seats, and an 08 style center console.
Im sure I can fab anything up to make it work, but im hoping someone here has done it or has advice to save me any possible frustrations I may run in to.
Thx,
Jer
Old 11-12-2010, 09:51 AM
My name is steve and I like to wear dresses
Old 11-12-2010, 09:59 AM
the 08 console install is a direct bolt in...
Old 11-12-2010, 10:12 AM
That nice. I dont judge. However I would suggest you take your issues to another forum where others like you can relate to your confession. Good luck with that.
Sounds good.
The seats I have in mind are typically used for rock crawling. They only have tabs on the bottom because they are intended to be used in a cage. I dont want or need a cage in this truck, just comfort on those long trips, or whenever I am jumping th etruck at the dunes. The stock seats arent intended to keep your spine in alignment doing that
Old 11-12-2010, 11:18 AM
I should add, the console is a direct bolt in, as long as you get the mounts with it that attache to the factory seat bolts...
