swapping seat covers - Ford Powerstroke Diesel Forum
Old 11-01-2010, 10:29 PM
bought a 05 F350 which has some wear on the door side edge of the driver's seat bottom, probably from sliding out since the truck had no step or nerf bars. I'[m thinking of swapping the passenger and driver seat cover from the bottom cushions which would place the worn area on the passenger's left side next to the console. Any experience with this out there? I'd appreciate any hints, shortcuts, etc or a strong warning not to try it
Old 11-01-2010, 10:36 PM
shhhhh, can you hear it?
you cant really do that.seats are built so that the inside is on the right on the drivers side and left on the passenger.i used to do car upholstery.wish it was that easy though.if you do have them recovered make sure they rebuild that part of the seat as the foam in that area is also probably worn.tends to be the case.
Old 11-01-2010, 10:40 PM
Thanks Big Angry. I was only thinking of swapping the covers off of the seat bottoms, not the seats themselves. They look identical, but I'm not the upholsterer. The foam seems ok, it just the thread fraying along the outside seam.
Old 11-01-2010, 10:42 PM
yea im talking about the covers as well,they are not identical unless something has changed since i got out of the business.
Old 12-27-2010, 02:53 PM
thats a good idea, wish it worked, my arm wrest cover was torn up good so i swapped the covers and now they both look good down and you can only see the torn place when the passenger side arm rest is up
