Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 05-21-2007, 09:02 PM
bigbear75 bigbear75 is offline
Overhead Light Console Removal
Does anybody know how to remove the cover of the console overhead that houses the light switches and sunroof switch? I recently removed the light lenses to install High out put LED's (http://www.autoalumination.com and would like to pull the whole cover off and mod it a little. Thanks!
Old 05-21-2007, 09:08 PM
Hayman Hayman is offline
First let me you to the site as to your question i have never pulled it off before someone will chime in and help you.
Old 05-21-2007, 09:13 PM
westcoaststrokin westcoaststrokin is offline
Go Navy! Beat Army!
to the ORG!! No idea to the answer but I will bump ya.
Old 05-21-2007, 09:17 PM
Thanks. I'm looking at painting it. I painted the rear light assembly housing black and it gave a good two-tone affect and would like to do the same to the front. I LOVE the LED lights opposed the OEM. They are alot clearer with a blue tint instead of the yellowish haze from OEM
Old 06-10-2007, 08:03 PM
Nobody wants to help me? *sniff*sniff*
Old 06-10-2007, 08:19 PM
WEWILLE WEWILLE is offline
ready for spring
I took apart an expedition console a while back and it just poped off with a little persuation from a screwdriver if i remember right.
Old 06-10-2007, 08:21 PM
So your saying it has like spring tension clips? So if you tug on it, it will pop loose? Do you remember if it came lose from the windshield side first or the other side? Thanks again
Old 06-10-2007, 08:25 PM
ready for spring
Ya i believe it has the clips, just be carefull the plastic is easy to crack. Sorry but i dont remember which side came off first, but i dont think it matters.
Old 06-10-2007, 08:30 PM
Thats cool, Thanks for the Info. I'll go give her a little tuckin and see what happens....I'll post in a few and let you know if anything gives....................
Old 06-10-2007, 08:32 PM
ready for spring
Sounds good, that is what the site is here for, hope it works out for ya.
