Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 05-09-2007, 10:25 PM
2005F250 2005F250 is offline
Door pop
On my 05 cc/sb the rear drivers side door makes a popping sound when driving down the road. I'm just trying to figure out what could be causing it. I think something could have broken inside the door from it getting slammed shut.
Old 12-04-2007, 09:44 AM
mgardner28 mgardner28 is offline
Did you find out what your problem was? I have a poping noise coming from my front drivers door on an 06 F250 SC.
Old 12-04-2007, 09:52 AM
Fordinator Fordinator is offline
Got the same problem on my 05 CC, it appears to be worse when cornering or going over somewhat rough roads.
I would be curious if anyone has found the solution yet.
Old 12-04-2007, 10:09 AM
SuperDutyPSD6L SuperDutyPSD6L is offline
Send a message via AIM to SuperDutyPSD6L
I have this same problem. Wow this is kinda funny
slammedSI slammedSI is offline
Wow i guess this is a common issue.. Mine does it too but only on rough roads.
Old 12-04-2007, 03:44 PM
420fitter 420fitter is offline
my truck also does this too 05 supercab but i thought it was more underneath the truck like body mounts or something
Old 12-04-2007, 03:48 PM
rankroddin250 rankroddin250 is offline
TURN THE STERIO UP! problem solved.
Old 12-04-2007, 07:39 PM
Thats what I did but my subs stopped working today. Hopefully its a loose wire.
Old 12-07-2007, 06:41 AM
Pop is mirror assembly
I removed my door panel yesterday to try and find the pop. When I drove the truck after the panel was removed I definatley heard the noise much better. To sum things up it is not anything inside the door panel. It is the mirror assembly! When I push and pull on the mirror I hear the pop sound. I can hear this inside and outside the truck. I folded the mirror in all the way and drove the truck. I did not hear the pop. I stopped and folded the mirror out and drove, again heard the pop. This does not make any sense to me. I checked the mirror on the other side and it does not make the pop when pushed and pulled on. Does anyone have any suggestions? Should I take it to the dealer and let them figure it out? I hate taking it to the dealer for stuff like this. They keep it forever and I normally have to take it back multiple times. Has anyone had the mirror assembly apart?
Old 12-07-2007, 06:58 AM
smuesse smuesse is offline
Mine makes a Pop/Rattle. When i put pressure on the door it quits. I started checking it out and found it to be the door touching the catch that holds the door shut. A bit of Elect. tape on the catch stoped it.
