Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 04-10-2007, 06:13 PM
NavyCPO NavyCPO is offline
Bummmmping, Rattle
trying to narrow down a bumping or rattle in fire wall area i guess> put some shims(cardboard) under the radiator fill bottle but still apparent noise is there. anyone got any ideas. (2004 6.0 Fx4 Ext Cab)
Old 05-15-2007, 11:44 AM
powerstrokecwby powerstrokecwby is offline
is it comming from the pass side, if so check the 3.5 inch down pipe and make sure its not hitting the pinch weld for the fire wall
Old 05-15-2007, 11:54 AM
mschn99 mschn99 is offline
ive seen the exhaust barely touch the framerail only when in gear too....check that out closely!!
Old 05-15-2007, 01:05 PM
2005F250 2005F250 is offline
With the exhaust is touching the framerail is it only when in gear and then when its in park, nuetral, or shut off its not touching?
