Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 10-27-2009, 12:16 AM
f250krew f250krew is offline
blacknblack
sub box
ok so im finally ready to put a system in my ford and i need to know what measurements of the boxes you guys have built for the back of your crew cabs and i dont want to move my seats forward and i dont have a power back window let me know what you guys have done any info will help
Old 10-27-2009, 02:01 AM
99250on14inches 99250on14inches is online now
umm if I remember my dimension on my box they were 6" at the top, 10" at bottom and 60some"s long...and for height it was directly under the panel under the window..I wanna say like 16" tall?? it was pretty sweet LOUD as hell too...had 3-10" MTX's inside it.
Chad
Old 10-27-2009, 08:18 AM
blacknblack
thanks man! that sounds like it will work
Old 10-27-2009, 08:29 AM
Snake Snake is offline
I had one from SuperCrew Sound behind the seat and wasn't 100% happy with the way it sounded. The subs were basically resting on the back of the rear seat and when they fired, they'd go off axis. Plus I lost a good 50% of my low end because of the rear seat. I ended up having someone build a fiberglass box out of my center console and put two 10's in it.
--Snake
Old 10-27-2009, 08:59 AM
TampaSteve TampaSteve is offline
Or a JL Stealth box, under the console.
Old 10-27-2009, 11:06 AM
Str8Ugly Str8Ugly is online now
ill be building a fiberglass box that goes from my dash to the back seat that goes up and over my back bench seat.. itll house 2 10" monitors, my amps 2 12's and my x360.. possibly even a carputer if im feeling snazzy
Old 10-27-2009, 01:17 PM
Ill be building another box like this but this time Ill have the buckets and flip up center console in the rear so we'll see how it works out this time....hopefully it does sound better....it should...
Chad
Old 10-27-2009, 05:54 PM
blacknblack
dang id like to see some pictures of that
Old 10-28-2009, 06:51 AM
if i cant build it ill have a friend in ft worth texas build it for me and he does some good work
not meaning to ***** up this thread
Old 10-28-2009, 05:22 PM
blacknblack
have any pictures of it installed? and does it just go over the stock bench seat? how much does he charge to make one? im interested but id need it cut for two 12 inch kicker solobaric l7s
