| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
About three weeks ago, I began to notice the smell of diesel fuel in the cab of my F-250 Lariat. I've looked to see if there's any fuel leaking around the fuel filter located top, front of the engine as well as any of the fuel plumbing but I don't see any.
Has anyone directly delt with this problem before? |
when this happened to me my fuel filter cap on the motor was warped and very very very slowly leaked i didnt see it at first look i thought it sounded odd but that was the my issue hope this helps you out
What kind of truck do you have? I had the exact same problem on my 08 and the dealer was never able to find out why....luckily it was a POS and I got rid of it. It seemed to happen when I had the vent/heater flow turned off and the windows cracked open, but it was annoying.
Good luck, |
I have a 06 F350, with the same problem. with fuel leaking mostly does it when its cold. But I found the problem(s). The fuel rail lines running from the fram rail pump to the fuel filter leak. there are male and female ends that have a oring inside that leaks. In oder to see them you have to take out your intake from the rubber boot forward. they are right next to the oil dip stick line. cant miss them. If you hold each side they should have very little movement. if they have alot that means the rings are bad. the stupid part is $185.00 cuz you have to buy the hole line set up from ford. its a pain to fix. the other part that leaks is the top fuel filter cap it does get warpt and will not seal right, one more is the lines going into the top fuel filter and out of it. teflon tape fixed mine. Only thing I have heard of beside these problem that I had, was the lines cracking but you can see the cracks. it all on the driver side of the truck. hopefully this helps you out.
Hi, I'm new to the boards. This is my first post. I have the same issue. light to moderate fuel/diesel smell in the cab. 05 F250 6.0, bought it used with 40,000 about a month ago and just becoming familiar with it. When I open the hood I can smell fuel also. Where is the fuel filter? I understand that there is also a plug to drain water. Don't mean to hijack the thread but the problems are similar. Thanks.
The Ford service manager said they didn't smell anything. I was there with the manager telling him there's fuel vapors coming through the vents...He just looked at me and said "I don't smell it." How do you deal with that? Anybody I've ever pointed it out to can smell it. Sometimes passengers comment on it.
i took mine in a couple times before anyone figured it out
Im not sure if your talking about raw diesel or exhaust smell of diesel There is a flex pipe or something from the turbo they leak and fumes come in the truck more so with the vents on ask your dealer my dealer is fixing mine for free
The more I get into it, I can smell just a slight sent of exhaust when I'm driving. When I pull up to a light is when I smell what I think is fuel although I'm not so sure it's not exhaust also. Might sound funny, but I'm not all that experienced with the smells on a diesel truck. But I'm leaning more towards fuel.
Is there going to be a significant difference, say like on a gas motor?
