Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 10-15-2009, 11:32 AM
rocky1074 rocky1074 is offline
Gauges
I'm looking to get a set of 3 pillar mount gauges Exhaust Temperature Gauge; Boost Pressure Gauge not sure 35psi or 60psi ?; Transmission Temperature Gauge. I am thinking about the Auto Meter Z Series. Anyone know about these gauges good; bad; ect. I am open for any other sugestions. Right now running stock 03 6.0 but in the future looking to upgrade Full EGR Delete; Oil Cooler; Studs; Exhaust; SCT-X3 Tuner. Looking Forward For Your Input. Thanks
Old 10-15-2009, 11:34 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
i can get you new ones: Auto Meter Gauge Kits
they are good quality kits....
-Raul
Old 10-15-2009, 11:44 AM
SuperCrutyPS SuperCrutyPS is offline
These are my Z-series Autometer - I went with the 0-35 boost gauge. I don't figure I'll be doing enough mods to push it past that. I basically wanna monitor stuff especially while towing my 5th Wheel....
Old 10-15-2009, 11:46 AM
stockcar12 stockcar12 is offline
john turnbull jr
Send a message via AIM to stockcar12
where do you tie the boost gauge in at on the motor and also the trans?
Old 10-15-2009, 11:55 AM
trans goes to the test port on the driverside... very easy to hook up... boost gauge goes to the Map sensor with a T fitting
-Raul
Old 10-15-2009, 12:31 PM
john turnbull jr
thanks raul
Old 10-15-2009, 12:34 PM
N.Texas N.Texas is offline
Where does the EGR hook in? Are they easy to install?
Old 10-15-2009, 12:39 PM
R U refering to the EGT Probe? The shop that did mine driill and tapped the driver's side exhaust manifold. A piece threads into that hole, the probe screws onto that piece. The thermo-couple is inside in the exhaust stream.
