Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 09-05-2009, 05:55 PM
NCfarmboy NCfarmboy is offline
GPS Mounting?
Alright guys -- I have a Garmin Nuvi GPS with the suction cup mount on the winshield. I love the GPS, but hate the mount. It's always falling.
Anyone have any good ideas for a permanent mounting solution? How about hard wiring in your GPS? Who's done it?
Let's see the pictures!!
Thanks!
Old 09-05-2009, 06:18 PM
05_PSD_Erik 05_PSD_Erik is offline
<---- That's My Kid!!!
I have my Nuvi mounted on the dash with the suction cup and the little black disc that comes with it.
Hope this helps. I have the wire ran down behind the dash piece ran down into the little pocket below my TowCommand. Where I have a two way splitter off the cigar lighter powering my Nuvi and Sirius Radio
Old 09-06-2009, 06:44 AM
Blitanicle99 Blitanicle99 is offline
My Garmin Nuvi has the suction cup mount with the latch that tightens it down... I put it on the top of the winshield to the left of the mirror, right before the bumpy stuff.
Has yet to fall in the past month. And my wire is just tucked up in my A pillars and headliner...
Old 09-12-2009, 09:55 AM
Dang... I wish I knew where that disk was. Anyway, any more ideas? Thanks!
Old 09-12-2009, 12:03 PM
charlesrf600 charlesrf600 is offline
Send a message via AIM to charlesrf600
I put mine in the middle of the widshield at the bottom. That is the only place that seems to hold everday with out fail
Old 09-24-2009, 03:35 PM
yosh30 yosh30 is offline
well i was braing storming the other day, hate they way my gps just stands out(just like yourself). so i started looking around. im going to order the edge overhead pod than custom fit it so my gps sits in it, fiberglass a back plate for my gps, get some strong velcro(so i can still take it in and out) and set it up. i would hard wire it in going in the cieling down my gauge pod..and probably get a tint banner too so you cant see the ugly edge pod from the outside.
what do you think?
i was also thinking of doing it with the dash mount that edge offers, but my gauge pod would be in the way
Old 10-03-2009, 05:49 PM
what do you think?
Yosh --
Sounds like a great idea!! Please post up some pictures if you go forward with this idea!
Old 10-03-2009, 06:05 PM
im in the middle of it right now, had to cut up the edge overhead mount quite a bit, and its going to be a real tight fit on the headliner..ill try to get pictures some how..
elliot
Old 10-04-2009, 06:10 AM
1tonpower 1tonpower is offline
i bought a universal mount from radio shack. then took it apart, there the peace i used fit perfectly in the cigarette notch that is in the center cup holder.i used a small screw that i had left over from the mount and screwed it to the ash try. as long as the ash try was fulll of change."usually is" it would be fin. you could even push the cup holder back in the dash with this mounted. it wouldnt go in all the way but if you needed the center seat you could use it. best thing is, the ash tray is removable, and there was only a short run over to the 12v plug to minimize the wire hanging there..
sorry guys no pic of the set up. that truck is in a better place now =\ i have a similar set up in my 08 i can show you
Old 10-04-2009, 06:16 AM
choupique108 choupique108 is offline
In search of 20s
Location: Lake Charles, Louisiana (currently Shawano, WI)
Originally Posted by 05_PSD_Erik View Post
I like that, i just dont know what i did with my disk thing.
here is how i have mine, it only seems to fall off when it gets really hot outside and i park in the direct sunlight. If i wipe the windsheild off where i stick mine it seems to do much much better as far as sticking goes.
