oil pressure or Fuel Pressure - Ford Powerstroke Diesel Forum
Old 06-21-2009, 11:14 PM
i've got pillar pod gauges and was wondering which would be better to install next fuel pressure or oil pressure? i have the egt trans temp and boost gauges already installed but i bought the pillar pod with 4 slots so which would be better to put in?
Old 06-22-2009, 02:12 AM
Lt. Negativity
Oil Pressure with at the Filter or ICP, Fuel pressure when you get yourself a upgrade fuel system, or regulated return.
Old 06-22-2009, 03:43 AM
EOT or ECT would actually be better choices at this stage in the game for you then oil or fuel psi.
Old 06-22-2009, 06:00 AM
Feedback Score: 5 reviews
^^ I agree
Old 06-22-2009, 10:51 AM
Send a message via Yahoo to Lubbockguy1979
Tex know what he is talking about. If you want oil pressure you need a hpo press
Old 06-22-2009, 12:10 PM
Lt. Negativity
Thats what I meant by the ICP sensor that is where it is normally taped into.
Old 06-22-2009, 05:12 PM
If you're running a tuner then fuel pressure is critical with or without a regulated return. Oil pressure will basically take care of itself in that if you lose oil pressure the engine will shutdown anyway. EOT and ECT can be read via the OBDII port where as fuel pressure must be added since there is no sensor.
All in all it also depends on what you're doing with your truck. If you're towing a lot then the temp gauges are the most critical.
Old 06-22-2009, 06:13 PM
Well in all honesty, it would have been better for him to get a DashDAQ and what isn't monitored thru the OBD-II, he could have gotten analog sensors run thru the DashDAQ and gotten EGTs and Fuel pressure that way considering he could have also gotten boost and trans temp thru the OBD-II(and 460 other sensors) as well.
I would argue that having an ECT or EOT is also critical if he is running a tuner and has stock headbolts as getting to operating temp is really the best before he starts ragging on the truck with the tunes. In that case, I would say that EOT or ECT is as just as important as Fuel PSI if he is running a tuner and it is really important even if he isn't running a tuner because you can still rag on a stock truck before it gets up to operating temp and blow headbolts as well.
Old 06-25-2009, 01:41 PM
LMAO.....You are correct....he should have gotten the DASHDAQ. I was giving my personal opinion based on what I'd had the most problems with and the temps haven't been so far (knock on wood) except for EGT's, which are self inflicted. I just happen to think that fuel is a LOT more of a problem than most people might realize. At least the dash gauges will give you clue on ECT and oil pressure even though they are 99.99% worthless.
