Straight Pipe - Ford Powerstroke Diesel Forum
Old 06-21-2009, 03:16 PM
Straight Pipe
Hi, I have the banks monster exhaust system on my truck. I've been told by many people to take the cat off and put a pipe in between. The dealership said some bull**** about back pressure but I had a feeling that they didn't know what they were talking about. So should I straight pipe it? What's the most affordable solution to go with? What are the benefits?
(I can't afford much right now haha)
Old 06-21-2009, 03:21 PM
I would straight pipe it! Mines been straight piped since the day I got it. There are a few companies that make cat delete pipes or you could get a muffler shop to make you one.
Old 06-21-2009, 03:38 PM
I got one from Pure Diesel Performance, got it for about $65 shipped. I would buy an actual cat delete instead of just a "pipe" in between, because you can put the cat back in place with this if you need to.
Old 06-21-2009, 03:45 PM
They are full of chit..
Old 06-21-2009, 03:51 PM
Can somebody take me to a website? I really don't want to order the wrong sized one for the banks exhaust.
Old 06-21-2009, 03:52 PM
what size is it 3.5, 4, 5 ????
Old 06-21-2009, 04:20 PM
this is the one i have, went in quick...( if you have a 4", this is it )
03-06+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
Old 06-21-2009, 04:23 PM
The TURBO makes 14psi of backpressure and diesels don't need backpressure anyway.
Old 06-21-2009, 04:55 PM
for the banks exhaust they have you cut the cat about a foot short to make it fit into their pipe which is BS but you have to fet a piece of pipe to put between the two sections of pipe. Any 4 inch muffler delete should be fine though. I wound up having to get 3.5 inch pipe and it fit inside the two banks pieces (of crap) and filling the gap left by the cat. then i just tightened the clamps they had. I would just take it to a muffler shop and get a piece of pipe that goes from where the cat begins to the muffler ends. This way it will be really easy to switch if you have inspections. just might take a little bit of time to find a shop. when I called around they were all real strict on the epa regulations and I didnt have any luck.
Old 06-21-2009, 09:36 PM
When I swapped my exhaust to the 4" I also removed the cat with the delete pipe. A couple weeks ago I put the cat back in since it was going to the dealer for warranty work and the power loss was noticeable.
As soon as I got it home the cat came back out.
