SCT Help
You guys know I bought the SCT I have from ID Xstreet tune I did a full egr delete on the truck over the weekend and just for piece of mind I put the truck back to stock. Did the mod and went for a ride the truck felt great a little more peppy and I was thinking that with the tuner It really ought to shine. But when I put the tune back on the truck feels dead compared to no tune at all what gives the egts went up to way up as well but not any more power? and thats the way it was before I did the EGR delete. I drove it with the stock set up for a couple of days before the mod and it felt like a beast. it like the only thing the tuner is doing is making it smoke and get hot but not really going any where.HHHHEEEELLLPP!!
Heres a bump for you, I have no clue
wow... im stumped... i'll give you another bump though
im thinking you bumped some censor loose in stock mode it might default to standard parameters.....but i would think when you use a tune it pushes the "window" on the reading it recieves causing a fault and no power....
1) did you get a CEL 2) look if you pinched or disconected an injector wire while you were there 3)if you didnt do a compleet deleet than crack the cap on the overflow tank and see if you have greater constant pressure maby the EGR cooler cracked on the intake side of it now you have a boost leak 4)go back to stock then upload agin.. thats all i can think of |
oh look at the VGT see if that thing is pluged in could have poped out
well guys still no luck, looked for any thing that might be unplugged and nothing returned the truck back to stock and drove fine it would shift out of fifth with just a slight roll on to the pedal and then put the Xtreme street back in and the roll on in fifth had to be matted to get it to down shift up until then black smoke rolling from loading up starting to worry!!!
but other than the down shift in fifth does it run ok?
hey exteem PM me
we think we have it locked down to a sticking turbo the stock V-vein gonna take it off and clean it ! keep ya posted
I poured a quart of atf in the tank and it lubed the viens in the turbo and all is well now!!
