Fluidampr
What are the benefits??
It reduces engine vibrations at higher rpms. Really only needed when you do mods that move the engine's rpm range up past stock figures. That would mean injectors and/or turbo(s).
I wouldn't put one on a 6.0 if it was free.
Probably not a bad idea for a stock or lightly modded truck, but I've personally seen 2, and heard of many others that crapped the LPOP gear and ruined the charger when running a fluidampr in a high HP 6.0L. By high HP I mean over 500 in both instances I'm personally familiar with. Some of these same people went back to the factory dampener and haven't had an issue since. Just my 2 cents. |
I like mine alot..idles really smooth
As I seem to recall, the ones that you are familiar with also "lived" in a very harsh environment(racing) and for racing it is actually a different story then those that are used for towing or street work(not racing type of street work). |
very true, plus lpop gears have been known to blown in stock form..
I like mine, i think it was a good investment. |
![]() I seem to remember that the "higher HP" failures wear on stock lpop gears. There has also been a bit of talk about fluidampr's and failing lpop's on 7.3's, but that was over a year ago. I believe that if the lpop is going to fail on either engine, it isn't because of the fluidampr. There was even 1 case of a lpop failure using the ATI setup. For my .02, I like my fluidampr.
I like my fluidampr. granted it is a 7.3 but I've had mine on for over 2 years now and not a single issue...
I've had mine on for almost 3 yrs now and no issues. Trust me, I've had my fair share of issues, but none that I could like to that.
So whats the verdict?
