Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 02-15-2006, 04:49 PM
03stroker 03stroker is offline
how can i get my 6.0 to blow smoke
ive got a 6.0 with the edge attitude with intake and bullydog exhaust...and it doesnt smoke that much...whats up with that??
Old 02-15-2006, 05:38 PM
toobadq toobadq is offline
Black smoke is unburnt fuel, or more correctly, not fully burnt fuel. Unburnt fuel is white, as on cold start up. If your truck has a small puff of dark gray smoke when you mash it then your just about right. Black smoke can be harmful to your horsepower. If the flame front cannot burn correctly then you may be lowering you exh. temps and thus not spinning you turbo as well as you could.
Old 02-15-2006, 06:41 PM
powerstrokekiller powerstrokekiller is offline
Send a message via AIM to powerstrokekiller
if smoke is all you want unplug your turbo line to the intercooler, stop up the air filter. Or you could get some tranny mods and give ts performance a call. There chip is the only one that I know of that will always blow smoke.
Old 02-16-2006, 03:55 AM
SRDIESELSCOTT SRDIESELSCOTT is offline
I also have a 6.0L that has Edge A2 w/juice platinum,stacked with Edge evolution,AFE stage 2 intake,water/methanol injection,4" stainless magnaflow exhaust and It does not smoke,but it does smoke about everything else on the road.My trucks fuel and air mix is just right. Too much smoke is loss of power and waste of fuel.
Old 02-16-2006, 05:47 AM
Rodslinger Rodslinger is offline
Gun Nut
Hey Scott have you done anything to your heads at all?
Old 02-16-2006, 09:12 AM
I currently have a set of heads at machine shop being polished and ported. When I get those back I'm going to pull cab and install head studs and new heads. Can't wait.
Old 02-17-2006, 03:15 AM
Gun Nut
But with all the power you're putting down you haven't succumb to the dreaded head gasket blowing issue?
Old 02-18-2006, 06:24 PM
No I have no headgasket or head bolt problems at this time and at 40psi of boost you would think it would. I guess I got a good one and drive it with a sense of respect. If all holds together I will be giving a run for the money at the DHRA drags in June at Indy. One for the 6.0L's.
Old 02-18-2006, 07:47 PM
power95 power95 is offline
I LIKE CHROME :)
Send a message via MSN to power95
if u want smoke turn up your fuel pump
Old 02-26-2006, 09:15 PM
Fantom Fantom is offline
Send a message via AIM to Fantom
I've got a edge platinum, and when I have it on level 5 or 6 it smokes like a freight train when I get on the go pedal.:burnout
