SCT plus Insight equals Chrysler?
I installed my Sct today and now none of my Ford specific pids work on my Insight. The only brand that shows up at all is Chrysler. I tried updating the insight but haven't got to the SCT yet. Edge tech support didn't have any useful help for me. Has anyone else had this problem? Or know how to fix it?
I have the dashhawk which is pretty much the same thing and I had the same issue after SCT. I uploaded the newest dashhawk software on the device and it fixed it but I had to reset all the parameters. Honestly I just got over dealing with the dang thing and I'm just gonna spend the extra money and buy gauges instead of fiddling with the thing everytime I start the truck.
Actually they updated me with the dashawk software but it still didn't work. I uploaded my profile though so maybe I ha e to start fresh.
Anyone else running this combo? Just wondering if its just a canned tune problem that will go away when I get custom tunes?
I am running the insight with custom tunes. I recently updated it and have not had a problem nor did I have one before. Try disconnecting your batteries so the Insight has to rescan your VIN# and when it ask to use the predefined settings say no.
If I just unplugged the insight wouldn't it rescan?
I am not sure but I unplug mine all the time and it only ask if I want to use the predefined settings. But when I disconnect the batteries it ask what type of vehicle it is and what type of fuel.
Alright, I'll give it a shot..when I first hooked it up its asking what type of fuel but it's skipping the what type of vehicle question and seems to assume its a chrysler!!
Yeah, see if that works. I forgot that mine ask what type of fuel when I just unplug it. Maybe it will work and if not I don't know what to tell you.
I just got my insight and am running a SCT custom tune. Exact same problem. At first the Insight wouldn't communicate with the truck while running. So I tried just turning the ignition on, not starting and it worked. It then kept cycling on and off over and over. I left it for 15 minutes, thinking it may need to do something. THen after that I unplugged and plugged in again and it worked. Later in the day I was messing around with the display config. and then it turned off?!?!?! So if restarted the truck and it defaulted to Chyrsler. I'll try disconnecting the battery, but shouldn't there be some reset to set the insight back to it's original state before using it?
