EGT with ARP - Ford Powerstroke Diesel Forum
Old 06-14-2009, 11:31 AM
Send a message via AIM to BLKF250
EGT with ARP
I know with factory headbolts you dont want your EGTs to get up to about 1300-1400 degrees...So if you got the ARP studs in what would you guys recommend..or with ARP studs it just makes it more safe to hit 1300-1400 degrees.
thank you
Old 06-14-2009, 11:43 AM
The valves will warp and the valve contact points on the heads will slowly creat gaps. very small indentations.
Old 06-14-2009, 11:45 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
With studs or not, you don't want to go past 1250 for a sustained amount of time
Old 06-14-2009, 11:48 AM
Old 06-14-2009, 12:44 PM
Lt. Negativity
1250 ?? Really I run about 1000 or so on the hwy with my truck, with everything I got done I wouldnt worry about it till you hit 1400, I know guys that hit 1600 at times as well just not long periods of time.
Old 06-14-2009, 01:04 PM
<-Day Of Fail now SOLD
That seems just a little high. But yes you can go much higher that 1250 but only for a shot amount of time. (drag strip, shot pull ect...)
Old 06-14-2009, 01:32 PM
ok thanks i just want to make sure....the only time i really hit those high numbers are when i get on it but thats only for like a sec or 2 but those numbers are also safe to for a quater mile?
Old 06-14-2009, 01:37 PM
yup you can hit well over 1250 for short burst. Most will hit that the hole way down the 1/4.
Old 06-14-2009, 02:19 PM
Lt. Negativity
Ya that is fine, you'll hit high temps at full throttle.
Old 06-15-2009, 09:06 AM
its a 200* temp difference with the EGT probe right after the turbo.
