6.0 factory turbo size
what is the size of the factory 6.0 turbo..... ??mm/??mm please. thank you
IIRC the inducer size is 57 or 58mm...
![]() Can't honestly recall right now. |
so if the inducer is a 58, whats the exducer or exhaust side. and is the 03 different other than the 10 blade
I'm not sure if the exhaust housing is any different on the 03's vs. the 04 and later chargers. I know they added veins to the wheel to increase spool up and quiet it down for the later years. I think 13 in the 04 and 15 in 05 and up.
so the stock turbo is a 58mm/??mm then
exducer is 82mm. duramax turbo is 88mm.
There is a 3mm difference in size as well. The 03 turbo is capable of about another 15-20 hp over what the late 6.0 turbos can produce.
