studs injectors and now a noise - Ford Powerstroke Diesel Forum
Old 06-07-2009, 05:55 PM
i just did injectors, head studs and egr delete in the driveway with the cab on. eric sent me new tunes and it runs awesome but when i was pulling a grade i put the pedal down and right at 30lbs of boost i heard an air noise like fast short whistle blows and the boost gauges starts fluttering but i am not loosing any coolant and it's not puking. any ideas, thanks.
Old 06-07-2009, 05:56 PM
wriott
Guest
Posts: n/a
did your EGTs go up??
Old 06-07-2009, 05:59 PM
i don't think so
Old 06-07-2009, 06:01 PM
wriott
Guest
Posts: n/a
i would check to see if any of your boots came off or are damaged and its a boost leak your hearing.
Old 06-07-2009, 06:05 PM
Might want to check your up pipes and up pipe connections to the turbo and be sure there is proper torque on all the fittings...
Old 06-07-2009, 06:13 PM
could a cracked up pipe make that noise
Old 06-07-2009, 06:14 PM
wriott
Guest
Posts: n/a
it could... but i doubt that is the problem
Old 06-07-2009, 06:17 PM
i have tried to get it to do it on flat ground but i can only build like 28lbs of boost i have pull a grade to hit 30lbs and that is when it starts
Old 06-07-2009, 06:18 PM
wriott
Guest
Posts: n/a
i would check all the boots (easiest to do) just start eliminating possibilities
Old 06-07-2009, 06:20 PM
but your not thinking head gasket
