exhaust with a regular cab question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-07-2009, 08:53 AM Thread Starter
PowerJoker6.0's Avatar
i should have researched this on my own but i think ill get a more detailed answer here. my friend has an 04 duramax regular cab and he was telling me that they dont really make exhaust kits for regular cab duramax diesels because most trucks on the road are extended or crew cabs. he solved the problem by just using a magnaflow exhaust for a extended cab without the muffler and i guess it fit pretty well. will i run into the same problem with my regular cab powerstroke?
PowerJoker6.0 is offline
post #2 of 4 Old 06-07-2009, 09:13 AM
jamstoyz's Avatar
i dont think they make a kit for the single cabs. you can get one custom bent for you tho.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #3 of 4 Old 06-07-2009, 09:14 AM
No, PSD kits fit much nicer than Dmax kits....
JAcktheBear3 is offline
post #4 of 4 Old 06-07-2009, 10:22 AM
bugstroke's Avatar
magnaflow, mbrp, or any of the major brands can hook u up and fit great
03 Excursion 6.0 Eddie Bauer 4x4...egr delete, sct with custom innovative tunes, blue spring mod, Zoodad mod, 6.4 banjos, 18" Harley wheels. 4" turbo back exhaust with 6in tip, dieselsite coolant filtration system.
studs, 4" lift with 20x12s and 33s, factory 05-07 headlights......all coming sometime when cash flow allows!
bugstroke is offline
