SCT Help - Ford Powerstroke Diesel Forum
Old 06-06-2009, 08:00 AM
SCT Help
I am working on programming my buddies 07 6.0 with an SCT x3 with innovative tunes. I got the latest firmware and updater but when I hit "Load Custom Tune File" it brings up a "failed to read data" error and then when I press OK it says "Not a Valid SCT Device"
Any help? Please try to put it in normal language, Im not to good with computer crap
Thanks
Old 06-06-2009, 08:01 AM
Almostdunfukinwidit
you didnt upload the F150 only firmware did you?
O and Eric said that he never seen this before and told me to uninstall the updater and reinstall it. It's still doing the same thing after trying that.
Old 06-06-2009, 08:02 AM
I dont believe. Its the bottom download on that page correct?
Old 06-06-2009, 08:04 AM
Sh1t. I think I downloaded the wrong firmware, I used the non enhanced version.
Old 06-06-2009, 08:09 AM
I put on the right firmware and its still doing the same error. Does the SCT have to be on a certain screen? Also even just pushing "Display Device Setting and Serial Number" results in an error, "Unable to read Data"
Could it be a faulty X3?
Old 06-06-2009, 01:06 PM
Bump... I know there are ALOT of SCT trucks here
Old 06-06-2009, 06:15 PM
Lt. Negativity
Try pluggin in your SCT before you turn on liveload. You sould get a prompt that said Press ok once your SCT is at the main menu. I know with the X3 they are having a few issues with tunes being locked with serial numbers dont know if that is affecting you. Did you update all your drivers as well ?
Old 06-06-2009, 07:16 PM
The Flying Fynn
I was also getting this error today. I found it worked better on my old cpu with vista 32 bit it would not work on my brand new cpu which is vista 64 bit.
Old 06-06-2009, 08:19 PM
If i remember correctly when i installed liveload for the sct it said somehwere that it doesnt support 64 bit computers only 32 bit.
