EGR delete power gain? - Ford Powerstroke Diesel Forum
Old 06-05-2009, 11:04 AM
Some guy came up to me when I was at the race track that has 3, built 6.0's that have everything.
He said for about $350 he could do the half-*** Egr delete and it would give me about 30 h.p.
Can anyone back this up?
Old 06-05-2009, 11:10 AM
i didnt think deleting the egr gives you more power, i thought it's because it's prone to breakage that people deleted it, but i could be wrong
Old 06-05-2009, 12:03 PM
Thats what I thought. But with the cooler running temperatures and not recycling 1200 degree fuel into the motor, I figured maybe it could have made some power.
Old 06-05-2009, 12:05 PM
I have the full delete and noticed no gain at all....
Old 06-05-2009, 10:17 PM
its just to help the oil cooler and headgaskets from failing
Old 06-05-2009, 10:46 PM
my kits are just a little more than that and they arent the "half-a$$ed" kits.... you wont see any power gains, you will just gain reliability from the motor... the tuner to shut the EGR system down will give you power gains
Old 06-05-2009, 10:48 PM
I read that on here somewhere else too, but I still can't figure it out. How does it help keep the headgaskets from failing?
Old 06-05-2009, 10:50 PM
My guess would be engine runs cooler, therefore the studs do not heat up and become weak which would lead to them stretching.
And alrighty, thanks for everyones input.
Old 06-05-2009, 10:56 PM
exhaust gasses flash boil coolant, which will then flow through the EGR cooler, the oil cooler and through the engine... when it goes into the engine, the weak heads on the truck will start to warp due to steam and put extra pressure on the EGR cooler and the Oil Cooler and cause problems.....
By deleteing the EGR cooler all together, exhaust gases dont go by the coolant, so it help prevent the problems... and then studs will make the heads less prone to warpage...
now that is the best I can explain... someone else may chime in and explain better than that... but hey, I tried to help
what the EGR was meant for was to take exhaust, recirculate it back into the motor to burn off excess fuel and carbons.... however the design of it was severely flawed and it only looks good on paper, but to meet emissions standards they were put in these trucks...
Old 06-05-2009, 10:59 PM
thats a good explanation
