Tire fiting?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-04-2009, 02:47 PM Thread Starter
bunch85e's Avatar
Question Tire fiting??
Iam lookin into 35 inch tires and rims. was wanting to know if i could get by with 35's and a leveling kit? they will probly be pushing 13inchs wide just dont wanna rub
2006 F-250 extd cab short bed 6.0 POWERSTROKE
xcal 3/quadzilla commander with innovative tuned by eric and dj's looney tune
4inch straight piped with 5inch tip
afe stage 2 intake system
LOOKS-----
Diamo Karet 117 machined black 18x10 rims 33/12.50/18 toyo M/T's.
15% window tint all around with 5% eyebrow
Recon Smoked led lights all around with harley headlights.
how about them smokeing powerstrokes!
bunch85e is offline
post #2 of 5 Old 06-05-2009, 06:58 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
I have tires slightly over 33" that are about 11.5 wide, no lift kit. 35s would fit, but the width would probably rub on my truck. Also, it depends on the articulation. In a hard turn with full wheel-up and tire flex... Most of the tire manufacturers or resellers say you need lift or larger wheel-wells. The problem is primarily front body contact under compression while turning.
Best suggestion is to post the tires and rims you want to use and see if someone has installed them on their truck. If no reliable info, mount one and see.
twoicebergs is offline
post #3 of 5 Old 06-05-2009, 07:24 AM Thread Starter
bunch85e's Avatar
this is an picture of a set up that is very simular to what i want 18inch rims but he has 35inch pro comp xtreme a/t's.with a 4inch lift.
LOOKS-----
bunch85e is offline
post #4 of 5 Old 06-05-2009, 09:22 AM
Quoted: 46 Post(s)
Here are the pics of the tire clearance for my 33.25" on my 01 with the wheels st in the worst position for clearance. Looks like 35s would be too tight without lift or body work. With your coils you might only have the bumper issue.
Name:	Tire bumper clearance.jpg
ID:	9289   Click image for larger version
Name:	Tire Spring Clearance 01.jpg
post #5 of 5 Old 06-05-2009, 09:24 AM Thread Starter
bunch85e's Avatar
thanks do you have a leveling kit?
LOOKS-----
bunch85e is offline
