RR Kit Install - Ford Powerstroke Diesel Forum
post #1 of 28 Old 06-04-2009, 02:15 PM Thread Starter
06F250powerstroke's Avatar
RR Kit Install
how long should it take, is there any tips or tricks to no about putting it on
thanks
06 STROKER
lots of fuel more oil and a efr
06F250powerstroke is offline
post #2 of 28 Old 06-04-2009, 09:45 PM
fx4f150's Avatar
what is RR kit i dont think ive herd of this
2006 Stone/Tan F350 FX4
Muffler and Cat delete with 10in tip
SCT X3 by Eric
Edge cts
190cc industrial injection injectors
led's all over
Smoked recon lights
17in rockstars
35in trailgapplers
fx4f150 is offline
post #3 of 28 Old 06-05-2009, 07:57 AM
fordfan30's Avatar
regulated fuel return, heard there is one bolt on the back of one of the heads that is a pain.
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
post #4 of 28 Old 06-06-2009, 07:02 AM
That would be the drivers side return port.
hpprose is offline
post #5 of 28 Old 06-06-2009, 08:14 AM
thanks
probably 10 hours or more if it is your first one
hpprose is offline
post #6 of 28 Old 06-06-2009, 08:30 AM
Lt. Negativity
RescueF250's Avatar
My advice, being that ive done it before and a few times. Loosin up your y pipes, take it off the turbo, also take them off your exhaust manifolds. This will give you room to get in there. Make sure you have the right allen key and not strip it.
The front of the heads are the hardest part to get to with all that junk up front. Give yourself at least 2 days incase you run into a problem.
Matt at Gearhead,Doug at GoGo,Dave at Diesel Innovations,Ryan at Full Force Diesel,Eric at Innovative. Adam at First Coast
Built 2003 with 04.5-07 parts,Hey its a hybrid
Totaled
New Era Rescue 08 F250 CC/SB No limit stuff, H&S stuff, Fl pro stuff.
RescueF250 is offline
post #7 of 28 Old 06-06-2009, 10:14 AM
fordfan30's Avatar
10 hrs, 2 days, holy crap ist it worth it? I saw a kit at DFA I was thinking about.
post #8 of 28 Old 06-06-2009, 02:20 PM
one word: YES
hpprose is offline
post #9 of 28 Old 06-06-2009, 02:23 PM
back in the saddle
shu873's Avatar
Originally Posted by hpprose View Post
one word: YES
I agree wholeheartedly...
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #10 of 28 Old 06-06-2009, 02:42 PM
cliford's Avatar
i havent installed one on a 6.0 but on my 7.3 it took 3 hours maybe. the back check valve is a pain
soon to go?:
2000 f-250
soon to come?:
6.4 and spartan
cliford is offline
