installing turbo back, cant get DP off? - Ford Powerstroke Diesel Forum
Old 05-31-2009, 02:52 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
im trying to install my 4" MBRP turbo back system, ive got the whole stock exhaust off and the down pipe cut but i cant get the DP off the turbo, i did some research and found there is something to do with a clip holding it on? whats the easiest way to get this off.
Old 05-31-2009, 03:16 PM
C-5 Crew Chief
Send a message via AIM to Mattdc26
you have got the band clamp off the flange between the turbo and the DP?
Old 05-31-2009, 03:19 PM
i have the clamp loosened and apart, its tacked to the dp, i pushed the little tab on top of the DP up. is the clamp part of the turbo or the stock DP?
Old 05-31-2009, 03:23 PM
never mind i figured it out, this is probably the dumbest set up ive ever seen though on a vehicle to hold a pipe on
