Intercoolers???? - Ford Powerstroke Diesel Forum
Old 05-27-2009, 04:24 PM
Intercoolers????
Do the after market intercoolers really do what they clam for the 6.0"s or are they just a waste of money? I have it to spend and don't want to make a dumb mistake, really want to lower the egt's but don't want to spend the money if its not gonna do any good. help me out guys please thanks
Old 05-27-2009, 05:05 PM
I put a Banks on my truck and was very dissapointed. Save your money.
Old 05-27-2009, 05:31 PM
you dont need it with your mods
Old 05-28-2009, 03:41 PM
any more input??
Old 05-28-2009, 04:10 PM
I put in a Banks intercooler because I got it used of craigslist pretty cheap. I'd say unless you're running bigger injectors and a different turbo with more boost they aren't worth it. Wait until you pop the stock intercooler.
Old 05-28-2009, 05:28 PM
Wow I thought the technicooler was worth it. I thought wrong. R you guys sure it it doesnt help one bit???? flow? cooler intake???
Old 05-28-2009, 06:15 PM
Nothing noticeable. I'm sure if I had an EGT gauge before I installed it I would have noticed a drop in EGTs, but the gauges went in after the intercooler.
Old 05-30-2009, 02:51 PM
i have the banks, didnt do much but like 150* drop in egt's cruising and i have bigger injectors and turbo. get the spearco or hypermax cooler. the banks CAC tubes dont fit very well and are a pain in the a$$ to put on. if you have stock stick and such and dont plan on upgrading, put water on it, that will do a lot better job than the I/C.
Old 05-30-2009, 03:10 PM
Wait until you have enough fuel for the EGTs to be a problem. your not going to notice anything, mabye a little bitmore turbo noise if anything. With a good custom tuner you shouldnt have an issue with EGTs. youll see about 100 degrees drop which really isnt that big. For your truck id say to take the 1000 bucks and save it for studs and an EGR delete so you can get some more substantial mods like injectors or nitrous. You might want to do the intercooler before you do the turbo to prevent possably blowing the plastic boot off the stock intercooler.
