Need Help with Edge Insight Monitor - Ford Powerstroke Diesel Forum
Old 05-24-2009, 06:00 AM
Just installed my Edge Insight Monitor and EGT Probe. Seems as if many things aren't working. The EGT says N/A and for some reason I can not change the screen color. Any idea what may be wrong
Old 05-24-2009, 06:41 AM
had the same problem when i put mine in. you have to select the edge egt instead of just the egt under the screen where you choose which gauges will be on the screen
Old 05-24-2009, 12:19 PM
Thanks. That fixed the EGT. Any ideas on why I can't change the screen color. Its stuck on blue.
Old 05-25-2009, 07:13 AM
take your red and blue down to 0 % and it will make green, or adjust to the color you want.
