Who's got the best tranny cooler? - Ford Powerstroke Diesel Forum
Old 05-23-2009, 01:48 PM
Subject says it all.
Old 05-23-2009, 02:07 PM
Shaking the Bush Boss
Thought the 6.0 tranny cooler was the best...unless you run twin aftermarket coolers
Old 05-23-2009, 09:04 PM
I've been thinking about adding another cooler after watching my tranny temps on my recent trip towing Hwy 4 in the Sierra Mountains. Outside temps were only in the high 80ies. Tranny got up to 205 degrees. I thought that was pretty high... but what temps are you guys seeing towing in the mountains?
Once it got hot I really didn't want to cool off either. I expected to see my tranny temps drop soon after cresting the hill also, but the tranny didn't want to give up the heat. I was thinking another cooler would help get rid of the heat better.
Old 05-24-2009, 06:41 AM
My folks live in Sonora, so camping trips are pretty common in that area. I have been over Hwy 88 to Lake Tahoe and up hwy 108 in 100* weather pulling my 12k lb 5thwheel and never see over 180*. I do have a Mag Hytec Tranny pan, which does help some and also 4.30 gearing which I am sure helps alot. How much weight are you pulling? And what size are your tires?
Old 05-24-2009, 09:26 AM
Go with Mag tec and see what happens. Maybe its time for a tranny service. Temps seem kinda high given the outside tems. Were you in OD?
Old 05-24-2009, 09:32 AM
Almostdunfukinwidit
Avoid the aftermarket oversized tranny coolers like the plague. Unless you are doubled up on trans coolers as well.
If you are running an oversized pan with the stock cooler. The fluid will still get hot. But because of the extra volume it takes twice as long to cool.
If you are a 7.3 go with a 6.0 cooler or an aftermarket one with a fan.
If you are a 6.0 and getting hot which is unlikely unless you are running large tires and arent regeared. Get an aftermarket cooler with a fan and run it along with the 6.0 cooler
Old 05-25-2009, 11:51 PM
I don't know much about diesels but in my gassers I have had very good luck with the B&M Super Cooler. It has an electric fan too.
Old 06-19-2009, 07:11 PM
Sorry for the delay, I've been distracted.
I also have the tranny pan. Don't remember which R&P I have, but it came with the camper package, so I'm pretty sure its got the low gears. On that trip the trailer was around 11k pounds. Tires are oversized... 305/70R17.
Tranny fluid was replaced by me when the new pan went on last year... then again by the dealer a few months later when I complained the tranny was shifting harshly. Tranny seems to be shifting fine now and with all the new fluid it got I'm confident it doesn't need to be serviced. Truck just turned 60k miles. I always put the tranny in tow/haul mode when towing too.
