has crank but wont turn over - Ford Powerstroke Diesel Forum
Old 05-23-2009, 08:28 AM
Send a message via AIM to BLKF250
just did headgaskets and studs and truck wont turn over check all my wires and harnesses batteries are on a charger it has a strong crank but wont turn over is there something i have to do? It has fuel in the fuel filters and oil pressure any one?
Old 05-23-2009, 10:32 AM
help any one ive been cranking it for 4 hours and it wont turn over oil pressure is up oil is filled to the max there fuel in the fuel filters iam i suppose to do cycles or something? i usually crank it wait a lil bit then try again.....how long is this suppose to take?
Old 05-23-2009, 11:59 AM
4 hours any the battery isnt dead yet?..it shouldnt take more then 5-10 mins to build pressure and fire up.
Old 05-23-2009, 12:46 PM
ahh yeah about four hours 5-10 mins? that seems kinda quick
Old 05-23-2009, 05:44 PM
Jersey Strokers Asst. Dir
Send a message via Skype™ to Aronda1125
Check the water level in the batteries, I know it's probably not that simple, but I had something similar happen to me and we checked everything, looked everywhere and finally added a little water to the batts. and she started right up.
Old 05-23-2009, 06:46 PM
how would i check that and what would that do....it seems like the crank isnt spinning fast enough
Old 05-24-2009, 04:00 AM
Take the cover off on the driver side and there should be 2 removable caps on top. Just pop them off and fill the 3 holes w/ distilled water. The pass. side doesn't have a batt. cover, so the 2 caps should be right there. I fill them until they're around 1/4" from the top.
Old 05-24-2009, 04:10 AM
duct tape & zip ties
So what your saying is, the truck cranks and turns over but does not fire.
Is the above statement correct. What I suggest you do is scan for codes. Then go from there.
Old 05-24-2009, 08:31 PM
yeah when i pull my injectors or anything that requires me to crank the truck to build pressure i can get it to fire up within 10 mins
