Serious Help! - Ford Powerstroke Diesel Forum
Old 05-21-2009, 09:55 PM
Send a message via AIM to BLKF250
Serious Help!
ok so a month ago my motor was hydrolocking and i would turn the key foward and it would hydrolock then after doing that turning the key foward did nothing no noise quiet thats when i need there was a problem and there was coolant in the cylinders i clean and suck all that out spun the crank and it spun fine replace hg and put arp in replace oil cooler and put everything back together and i went to go start it and nothing no crank just turn the key and quietness is there a fuse that could of pop? anybody please!
Old 05-21-2009, 11:23 PM
Check your batteries with a volt meter.
Old 05-21-2009, 11:37 PM
i popped my ecm fuse once when i accidentally shorted across the AIH relay. kept the truck from starting till i figured out what it was.
Old 05-22-2009, 03:59 AM
batteries are good both range from 12-14 volts......reddye01 iam gonna have to look into that one
Old 05-22-2009, 05:00 AM
update all fuses that dealt with ignition or the starter or the computer are fine all senors are pluged in. injectors buzz when key is forward. the ground strap that goes in the back of the head to above the heater box it tight and secure again the crank spun when the heads where off ( i only spun it a lil bit i didnt want to spin it to much)....But i did try hooking the starter up to the battery with jumper cables and nothing happen idk if that helps or not but i think it has to do with something electrical...any ideas any one
