sct help please. - Ford Powerstroke Diesel Forum
Old 05-19-2009, 03:46 PM
sct help please.
ok i have and 04 6.0 with manual trans, only mods are intake and straight exhaust into stacks. 60,000 miles on it. i put the sct x3 flash on about 3 weeks ago. ive had it on performance tune since i got it, i just noticed yesterday that mostly in 4th and 5th that when i get around 2,000 rpm and really get on it it kinda sounds like the trans or clutch or somthin is slippin cause it gets up to like 2700 rpm really fast then goes down a little bit but at the same time my boost is buildin strong and stuff, i did not notice this till yesterday, so is somthing starting to go wrong and should i switch it back to stock or is that normal cause it adds so much power?
Old 05-19-2009, 04:46 PM
If the clutch is slipping you would most likely smell a terrible burning odor when it happens. You could be spinning the tires?
Old 05-19-2009, 05:04 PM
well it does smell pretty bad when it blows black smoke, i got 35" tires on there so i doubt its spinnin, and why wouldnt it have done it before? i just dont know. it just has me worried i guess haha
Old 05-19-2009, 05:06 PM
You could try and select "firmer shifts" when you program your truck.
That's what I ran mine with, and had to problems. It was and auto though.
Old 05-19-2009, 05:07 PM
285,261,190
Try re loading the tune and see if the problem persists
Old 05-19-2009, 05:52 PM
yeah i tried reloadin it and it still happens. i may just take it off for good, i really dont think somthin is right and i cant afford to fix my truck is somthing major does go wrong
Old 05-19-2009, 06:11 PM
Send a message via Yahoo to Lubbockguy1979
probaably slipping the clutch. how many miles?
Old 05-19-2009, 06:44 PM
60,000 miles. is there somthin i can adjust on the sct to help fix this?
Old 05-20-2009, 02:26 AM
so if it is my clutch slipping for that short period of time should i be worried about it? enough to tune it back to stock and get rid of the sct?
Old 05-20-2009, 04:01 AM
An upgraded clutch would solve the problem. If you are on the stock clutch at 60k then Its probably about time for a new one, regardless of if you had it tuned or not.
If it was me, I would upgrade the clutch and keep it tuned!
