hypermax mach 7
Just curious if anybody has tried the hypermax mach 7 setup on their trucks and if it does anything for your transmission shifts.
will not do anything to the transmission. Only the motor. Make for a funky tranny...... NO..
I have ran the Hypermax Mach 7 for years now on my 6.0L and I have had no problems with engine or tranny, due to the module....Jeff and Max do a great job with products, and they really know binder motors and how to help them make power.....I think it's better than an SCT tuner, if you use the horsepower settings you better have your seatbelts tightened up good.
No. No. No. No. No. Adding hp without tuneing the trans is dumb. Might as well pour sand in your transmission. |
dont ever run a hypermax.
Never had a problem with Hypermax, have you guys?
I've never ran one personally, but I've read plenty of cases where ppl have smoked thier tc with them.
Your stock trans tuning is set up to handle stock hp. If you bump up hp on stock trans tuning, your tc slip will be higher, decreasing tc life. Custom tuning raises trans rail pressure and changes shift points to account for the extra hp gains. The topic of custom vs canned tuners has been beatin to death over and over again |
Actually there are a lot of guys using them around here on 6.0L and 7.3L, I know of 4 that run them on their 6.0L, now they don't hook to the sled on a regular basis but they to their tractors that hook to the sled with them....most of us use the #2 or #3 setting anyways, very rarely does anybody "need" to use the higher horsepower settings. I did know about Max, just was stating a general fact. Once again none of have our trannies beefed up, because we don't use the higher horsepower on an everyday basis. When we do I guess the difference in shifting points doesn't bother us that much. And last, to all of you out there who do pull your trucks I'm not knocking anyone elses tuning, this is just my experience, and I'll stick to Hypermax.
A Wise man once said, "Never pull the truck you drove to the pull." |
Like the other guy said.. Almost everyone uses SCT for a reason..Its proven to be the best for our trks. I dont know anyone who uses hypermax. But to answer your guestion, No I dont know anything about the new hypermax and im guessing I never will.
