To Shim FPR or Not to Shim? 05-F350 - Ford Powerstroke Diesel Forum
Old 05-12-2009, 11:14 AM
I've searched and it seems like this mod may be worth while??
Anyone have experience with this mod? yay or nay?
Will it noticable run smoother? better starts? power?
Thanks
Old 05-12-2009, 11:20 AM
Chapter Director
i've haven't heard anything about that mod i am curious myself
Old 05-19-2009, 06:59 AM
Must not work with the 6.0
Old 05-19-2009, 07:45 AM
What is your fuel pressure?
Old 05-19-2009, 08:26 AM
ADMIN AND TECH
this mod is not realy a big advantage , the thing about these injectors in these engines is , its not pushing more pressure they need volume , there is a big difference in the two, 7.3 or 6.0 both a spring regulator , but throwing the pressure way up is not that beneficial
Old 05-19-2009, 09:18 AM
I would only do it if your idle fuel pressure is low. If you lose pressure under throttle your pump is weak. I had about 53 psi at idle and added a .177" BB between the regulator spring and brass cup and I'm at 62 psi idle now.
Old 05-19-2009, 09:57 AM
An AirDog provides much better results, but isn't nearly as cheap.
