which air intake - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-11-2009, 07:30 PM Thread Starter
which air intake
im wanting to know what air intake sytems yall are running and if yall would recomend it so far im kindda leaning more towards the banks.....
Alex02ws6 is offline
post #2 of 14 Old 05-11-2009, 07:39 PM
no banks!!! afe, or if you can do a diy on the 6.0 you can save some cash, and still have good air flow, and filtration.
19558077 is offline
post #3 of 14 Old 05-11-2009, 07:55 PM
Raul@Stealth Automotive's Avatar
S&B is the best bang for your buck intake IMO.. S&B 6.0L Intake
Raul@Stealth Automotive is offline
post #4 of 14 Old 05-12-2009, 11:49 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
The stock system flows all the air you need.
CT Performance, Inc. is offline
post #5 of 14 Old 05-12-2009, 11:56 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I say DIY if it can be done. Other then that I second what Raul said!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #6 of 14 Old 05-12-2009, 12:18 PM
AIRAID Filters's Avatar
Hello Alex02ws6,
The AIRAID’s Overall Quality of Components, Fitment, & Performance are Second to None!
All AIRAID’s are Made in the U.S.A & Come with our Exclusive Lifetime “No-Hassle” Warranty!
AIRAID Filters is offline
post #7 of 14 Old 05-12-2009, 01:32 PM
tex25025's Avatar
No banks as already been mentioned.
You really don't need an aftermarket intake anyway. For a couple of reasons.
1. Quality and filtration is very good already on the stock unit and will handle what you need for a stock or just a tuned truck.
2. While a/m intakes do flow more, they don't flow more until they are outside the rpm range of the truck. Peak hp and tq rpms are at 3,300 and 2,000 respectively. The soonest that an a/m intake will flow more air then a stock intake for a 6.0 is at 3,700 rpm(that I've seen, someone knows of one within the 6.0s powerband please show it to me), well outside the range of the 6.0 unless you've done mods that push up your rpm range and that would mean injectors and/or turbo(s).
Now if your looking at an intake for other reasons such as being able to clean and reuse or ease of cleaning or changing, then you might have something over the stocker. However, for me that wouldn't be enough of a reason to swap it considering that would be the only benefit that I could see from it.
Unless your just dead-set on getting an a/m intake, I wouldn't do it.
2006 6.0 King Ranch DRW
Spartan Stage 1 Towing Injectors
Headstuds
Beta Spartan Phalanx
Suncoast Heavy Duty Torqshift Rebuild
ITP Fuel Regulated Return
Straight Piped MBRP 5" Exhaust
64mm Non-VGT turbo
tex25025 is offline
post #8 of 14 Old 05-12-2009, 02:04 PM
now how can you do the diy intake is there a page that has instructions?
1996 ford f-250 7.3 powerstroke, 4x4, auto, sc lb, 140,000, FPR shim mod, straight pipe to a 6" stack
1993 chevy k1500 suburban 6.5 turbo diesel and nv4500 5 spd.....workin out the details
dieselnut18 is offline
post #9 of 14 Old 05-12-2009, 02:05 PM
zippy557's Avatar
Send a message via AIM to zippy557
tex makes a good point, you dont really need one, but if you are going to get one S&B is a good choice great bang for the buck.
-Dave
'07 F250 FX4 Supercab SB
X3 ID Custom Tunes, ARP Headstuds, S&B Intake, ITP Reg Return Kit, PHP Atlas 80 tuned FICM, DC Power 250HD Isspro Performax - Coolant, Fuel Pres, Trans and Egt, 4" Turbo Back Straight Pipe FBD Exhaust, Zoodad Mod, Harley Head Lights, Recon Smoked Cab & Mirror Lights, White Night Back Up Light
zippy557 is offline
post #10 of 14 Old 05-14-2009, 06:39 PM Thread Starter
thanks guys for the info.. does the s&b filter as good as the factory one
