Match Turbo with amount of Fuel
What size turbo would be a good match for a set of 235cc injectors? I know that I won't be able to tow without having sky high EGT's, but am in the process of building my truck into a full on pulling/drag/toy truck
-French |
I'm running an H2E and waiting on my 210 hybrids to get to my house.
70+mm at least. you might as well go for some twins. 235's are pretty big. the guys truck above is a 7.3.
Thanks guys. I was reading through an older issue of Diesel Power and saw an '05 with 250cc injectors, a 70mm turbo, and some giggle gas. I want to stay away from Nitrous right now so I will probably be looking for a 70mm or a little larger.
-French |
I think most of the sled pullers are using a 72mm, since your already looking at a 70, might want to consider that unit as well.
You will hate it unless you go with twins. Those sticks with a big single requires running nitrous, there is no way around it.
well he will find out the hard way. good luck man i hope you have another vehicle for a dd.
-French |
