Where from here?
Alright, so I have an 03 6.0l. As of now the only performance mods are:
4" Magnaflow turbo back K&N air intake SCT X3 So being new to the diesel world, but having every tool known to man available to me (Thanks to friends!!) Where should I go from here? I use the truck as a daily driver and would like to be able to switch from good MPG's to scare the Civic driver. ANy thoughts or ideas would be helpful |
Head studs then EGR delete. Once you have that done you could go with a good set of 190 cc injectors and maybe a turbo. The 03 turbo should be fine though.
If you have the time and the know how, do EGR delete, studs and a fuel system while you have the cab off. I did mine fuel system while the cab was off and made everything 100 times easier. Just my 2 cents. Plus if you put a fuel system on now, even if you don't upgrade your injectors right away, it will be all ready when you do decide to upgrade.
-French |
