Cam Shaft question
What are the cams that some of yall have been running? What are the gains also???
I know of the Elite cam series. Stage I and Stage II. Some other machine shops have been cutting cams too. I am doing a Stage I cam in my current 6.0 build. It will increase the power range far above stock. You need to run aftermarket valve train because of the higher RPM range. v-8 style as of the 6.0 likes it that way....... I am interested to see how it turns out...so i will post results when the build is done.....sometime next month. I do know its a extensive install. Best to do with the motor out already....such as my case
I think most people on here are running stock cams.
I think your right on that........98% probably
