What guages does one generally need?
I have the boost guage on my console from the factory but it only goes up to 40 psi. Can I rely on it? Therefore, the only other two I need are the EGT's and what else? |
most factory gauges are highly unreliable so im not sure as to whether or not the boost gauge is reliable.
3 most commom gauges usally run on an automatic are Boost, EGT, and Transmission Temp. If you have a stick you could switch out the transmisson temp for a fuel pressure gauge or oil pressure or something similar |
Pyro is EGT, same thing.
Pyro gauge is most important. More than any of the others. From there, it is really just up to you. |
Pyro (Pyrometer) is the same as EGT (Exhaust Gas Temp)
I would highly recommend at least an EGT and a tranny temp gauge
