Un-plug the egr ? ? ? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-01-2009, 05:40 PM Thread Starter
I heared u can un plug the egr connection,
what does this do ? good or bad ??
will it throw a code?
thanks for the help.
05 f-350 4x4 cre cab long bed,
all AFE
leveling kit,
4 inch exhaust, straight pipe.:
65lemans is offline
post #2 of 3 Old 05-02-2009, 03:07 AM
Lt. Negativity
RescueF250's Avatar
Yes it will throw a code, your better contacting a vendor on here for an SCT, with the SCT they can actually turn your EGR off. So you dont have to worry about that.
RescueF250 is offline
post #3 of 3 Old 05-02-2009, 06:30 AM
tabraha's Avatar
And doing a block-off will help reduce the chances of it cutting up even more. Mine was turned off with the SCT and was still opening up when it shouldn't and my truck was running like dog poo until Scott welded it up for me. Then it was back to normal.
Tad Abraham
2005 F-350 DRW 6.0PSD Longbox
CrewCab 4.10's and a Limited Slip - Nicknamed "TINY"
B&W 5'er/Turnover Ball on top, better MPG than my half-ton
155,000+ on the clock
SCT X3, DJ's Diesel Performace Looney 160,Tow 50 and Econ 40 Tunes
Autometer triple pillar with Trans, Boost and Pyro Ultralite II's
4" Farmboys exhaust with cat delete
ARP studs installed and EGR Valve welded by Scott @ Trucks Unlimited
tabraha is offline
