Opening the exhaust up...
Im about to order an exhaust system and not sure if i should delete the cat and the muffler or one and not the other... the less restriction the better to a certain degree correct? with a 3 1/2 in down pipe to 4in the rest of the way out do u need a little back pressure to help the turbo spool? Is there any pros to running a cat? I don't have emissions test here so thats not an issue. Is it loud or just really deep straight thru? Let me kno what ur thoughts are.
Straightpipe it, you will like the sound
Straight piped trucks give me wood. j/k
But seriously straight pipe it. |
Most people say that a turbo creates its own back pressure. Id say straight pipe it. I love the sound of mine!
Straight Pipe it, with no muffler or cat, it is the only way to go on a 6.0L. I have a 4" exhaust on mine and absolutely love the way it sounds. Like I said before, you can't go wrong with a straight pipe on 6.0L. Also, the turbo has enough backpressure and won't sacrifice any time spooling.
-French |
I just did mine a week or so ago...I love it!..it gives a little deep tone when slowly accelerating and give it a deep rumble when you get on it...oh and at idle.. well if you stand on the passengers side it sounds like a jet!!!!
Awesome thanks guys... i appreciate it.
you will be happy if you straight pipe it and loose the kitty, the truck will sound like a jet
