SCT Problem
I just got my SCT today, I went out to my truck, plugged it in and downloaded my stock file. (I thought I had to do this in order to get the file so I can get custom tunes.) I wrote it down then tried to put the stock file back in my truck and it won't let me. Its saying there is an error. So, my truck won't start now. What do I need to do?
For right now you might just try to install a canned tune thats on the tuner. I had the same problem and i never got any help from sct. If you get a tune loaded on it you might be able to take it to ford for a reflash but they might charge you. Flash in tune see if it starts if it does. then see if it will let you reload the stock tune.
I had same issue - I needed to re-install the Firmware and had SCT write me a stock file
Did your Firmware load onto the SCt ok ? |
Umm...
Walk thru the instruction from start - ensuring that you download the Firmware to the SCT unit itself
What is the vehicle strategy ? |
The strategy is: vxbc9n8 The SCT says error 1016 when trying to put the stock file back The FW version is 1.2.106.0 |
can't help ya with a file - diff strategy..... exactly same code I got - Turned out to be the Firmware was incorrect on my SCT
Open the X3LWUpdater file Follow instructions for updating the Firmware on your SCT Try on Truck again If it fails - don't panic - SCT will take care of you - just sux not to be open til Monday |
Thanks for the help, but it says to return truck to stock before updating firmware. guess I won't be driving my truck this weekend, ha
Will SCT rewrite me a stock file?
Thanks for the help!!
