Re-use of head studs in build - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-25-2009, 08:50 AM Thread Starter
dukcaln's Avatar
So we all know that my motor (block) cracked. Well I got an 04.5 with 55k on it and will be doing a mild build....my question is this...can I re-use the h-11 headstuds from my 03 in the 04.5......I believe the size is the same just want to make sure.......While the motor is on the stand I am going to check the bottom end, replace some bearings if needed, add a stage 1 cam, stage 1 valvetrain, port the heads, port the manifold and port the exh manifolds, add chromoley pushrods, fluid dampner and new injectors. I am going to heat coat the exh manifolds, valve covers, intake manifold, down pipe, Inter cooler tubes and intake horn. I figured I would get away from the OUTLAW build since I picked this motor up for 2k......the motor has been trouble free for the owner.......I figured the cam and valvetrain will allow for an increased power range, porting everything will alow for the air I need for the injectors, lower egts, lower boost pressure and increase HP while heat coating everything will increase spool up, lower egts and look good. Fluid dampner to smooth things out and quiet it down a tad....With a good turbo and my water meth this thing should produce in the 500hp arena....What do you all think about the build?....Will the head studs work on the 04.5 that were in my 03? I think its the best, cheapest way to get this thing back running......the turbo will come after its completed and running....
04.5 LLY DURAMAX. EFI, AIR, FUEL, TRACTION AND MORE! POWERSTROKE SLEEPER SLAYER!!
dukcaln is offline
post #2 of 11 Old 04-25-2009, 10:10 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
As long as you have not overtorqued them and you use a moly thread lubricant you can reuse them. Same goes for the ARP studs. As far as the number of reinstalls, you would have to call the manufacturer. ARP wants 3 equal torques to specifications. I would assume the H-11s are the same. If my memory serves me right final torque is 245 ftlbs.
twoicebergs is offline
post #3 of 11 Old 04-25-2009, 04:37 PM
Contact the stud manufacturer and they will provide the specs for measuring the studs to make sure they are still good. Most times they are re-useable, but it is definitely worth checking them.
2006 F-250 4x4 ecsb, Elite stage 2's, VGT-SSX.
Vizsla is offline
post #4 of 11 Old 04-25-2009, 05:32 PM
03f250stroke's Avatar
yeah i would def check it out, i know of someone that stretched a pair of arps
-Evan
6.HO
tuned by Eric
12.3
Originally Posted by shu873 View Post
Yeah, but your trucks a freak of nature...
03f250stroke is offline
post #5 of 11 Old 04-25-2009, 09:10 PM
DryHeatDude03's Avatar
H-11s are tool steel and are re-useable
-Chris-
2003 F250 SC/LB 6.0L 4X4
DryHeatDude03 is offline
post #6 of 11 Old 04-25-2009, 09:15 PM
I hope ARP's are re usable. I sold mine with 7K miles on them.
2005F250 is offline
post #7 of 11 Old 04-26-2009, 01:52 PM Thread Starter
dukcaln's Avatar
thats what I was told....thank you
dukcaln is offline
post #8 of 11 Old 04-26-2009, 03:26 PM
redracer62's Avatar
ive reused my h-11's 4 times now
06 F-350
Trusted Performance
Innovative Diesel
Industrial Injection
ITP Diesel
Nitrous Express
Hypermax Rods and Pistons
13.06@102mph fuel only
redracer62 is offline
post #9 of 11 Old 04-26-2009, 03:30 PM
I'm not trying to sound like a d*** here, but you are spending thousands and thousands to get all that stuff done, and you want to re-use the head studs? It just seems like a bad idea to me. I would sell them, and get a new set, personally. I wouldn't want to risk all that work on a faulty stud. It's not likely, but it *could* happen..
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #10 of 11 Old 04-26-2009, 03:38 PM
back in the saddle
shu873's Avatar
ARP's can be re-used but the steel isn't necessarily made for it. They are torque to yield studs IIRC, just like the factory bolts. Any H11 is tool steel and they are designed to be reused time after time. If it were me I'd reuse them in a heartbeat.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
