SCT SF3 Questions - Ford Powerstroke Diesel Forum
Old 04-23-2009, 05:42 PM
SCT SF3 Questions
I picked it up used SCT SF3 for cheap! It has canned tunes as follows: Trans only, tow 50, tow 65, Performance and finally Street. What are the torque and hp gains? How do I know which tow tune to use when pulling my camper. Which tune, performance or street, will give the best fuel mileage? My 05 F250 6.0. is completely stock. Sorry for the many questions and thanks for any information!
Old 04-23-2009, 05:58 PM
Chug-a-lug!!!
I only use the 65hp tow tune. Performance is a 120hp tune that, if you keep your foot out of it, should give you the best mpg's.
You really need to get you a set of gauges or a monitor to keep an eye on your egt's, tranny temp, and boost. I would highly recommend opening up the exhaust to help get the heat out of the motor or else you stan a good chance of burning something up.
Hope this helps.
Old 04-23-2009, 06:20 PM
I would highly recommend gauges, exhaust, and custom tunes. Typically the highest horsepower tunes also give the best mileage, but are really not suitable for towing.
Old 04-24-2009, 04:12 AM
Thanks guys.........I plan to get gauges and bigger exhaust, but in the mean time I want to get the best fuel mileage. So, if I run a tune and keep my foot light, will I be okay? I'm about to head out for a 1000k road trip (not towing) and I certainly don't want to break something. And if understand, the "performance" tune would be better than the "street" tune?? Thanks again!
Old 04-26-2009, 05:59 PM
hey guys question, i just got the same tuner from xdp a few days ago, i have an 06 f250 6.0 i have been running it on street, is it ok to drive performance on the road?
Old 04-26-2009, 06:56 PM
Chug-a-lug!!!
Absolutely!!
Old 04-26-2009, 07:27 PM
Run it perfomance, it will give you the best MPG if you keep your foot out of it, it locks the TC up the most so there is less drivetrain loss.
6.0 with stock injectors dont really get outrageous EGTs, but the perfomance and race tunes advance the timing a little and thats whats not good for motor safety when towing.
For road trips not towing anything, run it in the highest setting you have.
Even with stock intake and exhaust the canned 120hp performance tune should also be safe for stock headbolts too.
Old 04-27-2009, 11:19 AM
oh well heck ya!! im going to put it on there right meow. i do have a straight pipe no kitty or muffler, so the egts should be fine too right? and i ordered some gauges earlier last week should be here soon.
Old 04-27-2009, 11:22 AM
As long as you don't put your foot in it and leave it there for more than 10 seconds or so you should be ok. With straight pipe on mine, thats when my EGT's start to hit 1200 or so and I get out of it. Maybe even sooner than that.
Old 03-15-2011, 01:26 PM
I just bought the sct sf3... ( thanks to every guy on here that recommended by the way its amazing).... My question is what gauges will i need? I have 5" exhaust and k&n also... thanks
